" rpms limited in water"
Did you gap them or check the gap? I know, I know, not supposed to have to gap the, they are preset. So are mine, and they are notorious for not being correct. So forgive the question, but did you?
No I did not. No gapping tool!!! picked them up from Canadian Tire, took them out of the plastic packet and switched them with the old ones.
Would be a bit strange as the new plugs made no difference from the old plugs..
Another thing you could do is swap the Coils from one engine to the otherand see if the problem switches to the other engine.
Hi Guys. Just to Re-Cap. 1st job i done, Changed plugs NGK CR9IEB. Thats when i noticed the Caps. 2 were rusty on the metallic strip along the shaft.
Need to replace them, anyone know where to buy?
thanks
stu
Are you sure that's the spark plug you used? The correct iridium plug for the mr-1 is CR9EIX. I used the iridiums last year but noticed no change in performance went back to CR9EB this year. If you don't figure it out I have the YDS software and cable. We could hook it up to your engine and see if there are any faults. You can buy your own on ebay for around $60. You said the boat is new to you. Did the boat have the problem when you purchased it. As mentioned earlier take a look at your air filter.
@Chillypilot thanks for the kind offer of the YDS connection. I have now purchased a cable off ebay. I hate borrowing stuff..Anyway gave it a go today and had no luck with getting a connection. Its been winterised now, so I will have to wait until spring. If the offer is still there @Chillypilot, then maybe i could trailer it over to you in barrie.
thanks again everyone.. Im going to my bed to cry now. :arghh:
@Stuart Bicknell I'm sure you'll get it figured out, but if want to bring your boat over here you're welcome anytime. The software can be a little tricky. Here are some instructions from the other board. Others may have some more advice. BTW my boat is all put away for the winter too:( Shrinkwraped it myself.
OK, I have installed the software and successfully connected and read the hours of my engines. Buck, I'll send the package back to you shortly. Here is the process from start to finish of what you need to do:
1) Install the software
2) Update the DB on the software (lauch the SW and press F1)
3) Locate your connection point on the engine. If you have a 2006 or less, it will be behind the cover plate in the rear starboard storage locker (yeah who would have thunk!). I am told on the newer models it is in the rear starboard part of your engine compartment. It will have one red wire on one side of the plug and 3 or 4 wires on the side you will plug into.
4) Plug in the YDS cable to your engine.
5) Start your engine
6) Turn on the water to your engine
7) Plug in the USB plug into your computer
7A) One time only step--you should get a "New Hardware" message...if the disk is still in the drive, it will find the drivers. If it is not, then browse to C:\Program Files\YDS\Driver
Launch the YDS software.
9) Hit Enter it should says something about communicating to the ECM. If it says it failed to communicate to the ECM, then either your driver didn't install or you aren't plugged in the proper sequence.
10) Hit enter and you should have a complete menu of items you can look at. For Engine hours click on "Data Logger" and then click on "Engine Operating Hours according to engine speed"
10a) If you wish to save the hours, click F2 to save the file (it saves as a .csv file or a "Comma Separated Value" file and an .xls file....in a nutshell....a file Excel can read, or most any data application like Notepad, wordpad etc.)
11) If you want to check out and see if you have had any engine "errors", click on the "Diagnosis", and then on "Diagnosis Record".
12) Shut off the water
13) Turn off the engine
Repeat for other engine.
There are lots of otherthings this software can do, but that is for another day. Here is what it read as an example for my engine hours:
Engine speed Time[h]
- 2000 r/min 30.67
2000 - 4000 r/min 53.97
4000 - 6000 r/min 7.4
6000 - 8000 r/min 27.82
8000 - 10000 r/min 11.2
10000 - 12000 r/min 0.99
Total hours of operation 132
@Chillypilot nice job of the wrap. Im paying Crates to do mine, but hoping next year i can get a garage of my own to store it in. I hate the thought of it being out in the -40 and snow...would rather it was in a garage so i could work on it. :)
yds... All i got was communication error. But I'm not sure if i installed the drivers or not. I use a Mac, so i had to instal on the old family windows laptop. So I'm not sure i know what I'm doing. I thought i read somewhere that you only had to just jump the engine to get the info for the engine. You didn't have to run it!! as I was out of the water and no where near a hose pipe.
It will have to wait until next year now. Im planning on getting the stuff I need to instal twin Battery. Bilge Pump. SS Scupper. Can you tell me where to get the scupper from? I also have a nasty little scar to repair!!! any one local?
Thanks again All...
Stu.
Checking in to see if anything ever get sorted out here? I'm having exact issue at the moment
