SCUBA diving from Yamaha 24 footer?
can you construct a 4 tank rack 2 plus 2 and have it go into the table leg hole?? just a suggestion center of the boat so less movement and better balance
Ooooo!!!!! I like that idea, but do you think the table mount will hold up to that much weight/momentum on rough seas or fast cursing speeds? Not sure that the backing behind the table holders are strong enough????
This was probably in reference to the old style table leg hole that was in the floor of the boat and not on the seat. I doubt the new side mount table receiver could handle this type of weight and flex.
ahhh makes sense, I'm dumb. lol
This is not what you are looking for. But, I think this situation is intuitive into the design of this mini scuba pack. Very small, lightweight, compact, and very easy to store.
https://getagripanchors.com/scuba
Doesn't answer your question, but I throw a couple tanks under the seat right behind driver's seat. The back area is AWESOME for diving, can sit with feet in water, pull on the BCD, then just slide into the water. Have fun!
