2nazt
- Port St. Lucie, FL
- Tidewater
- Other
Good idea I'll do a search for that thanks @jcyamaharider
I tried to reseal the tube that attaches to the scupper..... on the first disaster attempt at replacement. But the second attempt I did not. I realized there is no need to as long as the hose is on the scupper and the clamp is tight.Do you guys reseal around the clean out tubes? Is there any need to or just make sure the hose clamps are tight? I plan to reseal the access hatch and put some sealant in a few of the screw holes that are stripped out as well.
@Marvin willis. The crack usually happens on the scupper threads between the large plastic nut and the hull. Once the plastic nut is not providing adhesion to the hull the only thing left is the Silicon that Yamaha uses which I belive is not adequate for below water use. That will fail quickly leaving a 2.5 inch hole in your hull. This has been proven the hard way by several members.Ok I've been reading all the comments on this topic and I have a question. If the scupper valve is working, even if the treads get cracked, the flap should hold out most of the water correct? Gonna replace mine but I'm contemplating waiting til fall. My bilge never runs. Knock on wood.
There have been make members who decided to replace theirs and it falls apart in their hands when they touch it the first time... it's a rather large issue.. we replaced ours this spring the old one was not cracked and I saw no evidence of leaking but the plastic had began getting really brittle where u could take your finger nail and scrap plastic off of it.Y'all made me a little nervous.
That was me....my boat was a 2005, I replaced the scupper last fall. When I went to grab it from the inside to snap it off, I was expecting some resistance....it was like snapping a match stick.There have been make members who decided to replace theirs and it falls apart in their hands when they touch it the first time... it's a rather large issue.. we replaced ours this spring the old one was not cracked and I saw no evidence of leaking but the plastic had began getting really brittle where u could take your finger nail and scrap plastic off of it.
That was me....my boat was a 2005, I replaced the scupper last fall. When I went to grab it from the inside to snap it off, I was expecting some resistance....it was like snapping a match stick.![]()
What? The scupper? Oh... My wife and I are luck to be married after that saga! I had to trash the first one and buy a 2nd one. Where r u in Raleigh?Looks like this will be my first upgrade. Any of the Raleigh folks want to help a brother out?
I'm in zebulon... If u don't want to do it alone haul your boat up here and I will help... U have to bring the edges some for it to fit in the spot... That's where we messed up.. It wasn't sitting flush..Live in Apex
