Mainah
- Chapin, SC
- Limited S
So those with connext boats know all too well the shrill sound of the warning buzzer when they turn on their keys. The simple fix is to put tape over the buzzer. I did not like that idea as I want to be able to hear it at WOT with the stereo blaring and kids screaming in case a temperature, low oil, water depth or other alarm goes off.
My mod changes the constant shrill into a loud beep beep beep. I choose a programmable relay for this mod just as my push button start mod because it is cheap and I can easily adjust the beep and pause lengths. I also used the stock buzzer. Note that this is an easy mod and my install method is perhaps bit overkill as there are places to mount the relay board without have to make the separate board to mount it to. On to the photos, video, and instructions.
Warning Buzzer Mod.pdf
