dgfreeze
Jetboaters Commander
- Central Ohio
- SX
So OP, you have a reason to be concerned if the boat overheated. Unclogging the pisser was not a solution to the actual problem. Need to get that sorted out before purchasing the boat. There's a small intake screen located inside the jet pump, where water is forced through, and then runs forward, into the engine for cooling. Check that screen. In a perfect world, it's partially clogged. If not, I'd be a bit leery of that engine. Why would an engine that is getting coolant flow still overheat? Most answers to that question are not desirable in the least.
