Summers420us
- 242 Limited S E-Series
I bought two of these and ended up only needing one. Normally these run around $600, but I would like for a fellow jetboater to get it, so I selling at a loss. My screw up is your gain! Very easy to install too. From their website: SCR-24 Bronze Underwater Light - 24 LEDs - Full Color Changing The SCR series underwater LED lights are designed to be marine vessel hull mounted for continuous submersion in sea water. These models off a great value and small 4" diameter to fit many locations. Multiple brightness options are available as well as single or multi-color. High Intensity Shadow-Caster underwater LED lights are designed to deliver the most intense optical output. Our unique design allows us to produce maximum light output and maximum LED life (over 40,000 hours). Robust Design With Shadow-Caster underwater LED lights, there’s no additional external components to install. Just connect the cable (submersible to 20 feet). All the necessary electronics are integrated into the housing and resistant to vibration and the elements. Surface Mounted Our lighting solutions feature a low profile design that requires no alteration to the main hull Wide Input Voltage Range Shadow-Caster’s underwater LED lights have an input range of 10 to 30 volts and work equally well on sets of 12 or 24 volts. Surge and Reverse Polarity Protection Our lighting systems have an innovative protection system that automatically disconnects the input entry when excessive voltage or reverse polarity is detected. Thermal Protection Our unique thermal protection features a control system that detects internal temperature and adjusts energy production down to avoid damage. Features:
