Standard Garage Fitting Adjustments / Tire Pressure
jchandler311
Hey guys, I bought the 2019 ar190 two months ago and have issues with fitting in the standard size garage entrance. I've removed the bimini, its brackets and I have to remove the tower light and the tower still scrubs. Whats the lowest pressure I can deflate my tires to without causing any tire damage?
Make sure you've got the tower as low as it will go. Should go below the height of the windshield. 2019 models don't need the threaded extensions.
https://jetboaters.net/threads/how-to-get-your-2016-ar192-or-ar195-in-a-garage-less-than-7.10369/
Can confirm. I bought a 2019 AR and lowered the tower to below the front windshield. Just have to get up in there and adjust the nut on the support wire.
I do also have to lower the front of the trailer as low as it will go. I have to push the boat in by hand, as the boat sits too high when the trailer tungue is connected to my truck. Ended up buying a trailer valet to help out.
What size socket is needed to adjust the nut on the support wire?
