Edward
- Dallas, TX
Fellow Yammie Jetboaters,
Could use a little bit of help. Last couple days, got the boat all prepped...cleaned, oil levels checked & engines confirmed running okay....my normal routine before starting a season. All signs looked good, headed to lake with crew (lake ray hubbard tx), popped in down ramp, started engines, checked pee holes...all good..lauched, docked, picked up wife/kiddos. Head out, get outside no wake, throttle up.....25 seconds later...check engine starboard with the beeping in connext.....throttle down, check pee hole which is good....check engine compartment...looks good...shut everyone down...switch off batteries....wait a minute, restart and the same. start to move a bit to see if any more symptoms pop up...none...no cavitation, nothing irregular....try to shut it all down again, start up and still the same. decide to leave engine at idle while limp back on other engine about 4k rpm and then notice no water out of pee hole...throttle down and wait about 45 seconds...still no water from starboard pee hole...shut it down completely to be safe and limp back, load up and head home.
This morning I hooked up to flush the engine, started right up and water coming from all expected holes, meaning, pee hole & t-stat hole and exhaust port. Water temp not hot on pee hole but pretty hot on t-stat..measured around 140 degrees. Went into sys screen on connext and no visible error code there or on test screen...ran same procedure on port engine and exact same results....after tests checked under starboard side impeller to see the screen where water comes in and can't really find it so a bit confused there...do I need to take anything apart to see that? All signs right now look fine...no cavitation...no overtemp...i'm stumped.
So now I'm thinking low voltage battery issue...i have not completely disconnected the batteries yet. I do trickle charge when not in use and I am still on original batteries which my boat is 2015 ar240....so...maybe sympton of batteries going? I'm going to have them tested at autozone to see how they hold a load.
Aside from that, what else should I be testing/looking at?
Thanks!
Ed
Thanks!
Ed
