raptor319
- 242 Limited E-Series
2016 Yamah 242 E-Series...38 hrs. Just bought and getting Starboard Engine Overheat Warning after 15 mins or so running. Water coming out both pee holes but Port temp is warm as expected and Starboard is cold. Should it be warm since it is dissipating/transferring heat from engine? Thermostat issue maybe/salt crystals?
When I did demo run on it with owner...same warning popped. So I took it to shop and they ran a scanner on it and a lake test and could not duplicate issue.
Thoughts?
Thoughts?
