Starboard engine rpm cap while on water
nughaifn
Chaparral
VRX
My 243vrx starboard engine show check engine light with no fault code while in water and rpm wouldn’t exceed 4K. Port engine runs normal.
Once in trailer, starboard would rev normal to 7-8k rpm.
Not sure what could be the issue?
Is there anything stuck in the grate or behind it? That "alleyway" must be free of any debris.
Did you ever figure out the problem? I have sane issue. Starboard engine won’t go past 6k. Port fine. I replaced spark plugs and 2 of the starboard cylinders had water in them, manifested by rusted spark plugs that also had water droplets on them upon removal. Not sure how water got it, or how to remediate, but I bet that’s the problem. I went for a test run after putting in new plugs…but problem persisted.
