Steering Wheel Mod!
To remove a wheel off the shaft all you need to do is loosen the nut a bit and with the palms of your hands hit each side of the wheel a bunch of times. It usually comes loose. If that dont work then you have someone pull the wheel while you hit the center shaft with a brass hammer.
When i replaced mine it came right off with the palm method
