Cleveland Steamer
Jetboaters Commander
- Cedarburg, WI
New to me 2018 AR240.
Looks to be OEM stereo with the addition of a Wetsounds sound bar on the tower. There is no sound coming out the port side speakers or the sound bar.
Not at all a stereo guy here. Looks like everything is plugged in under the Helm, checked the balance between left and right side speakers.
Not sure what else to check. Maybe the wiring at each speaker. The sound bar won't even power up when pushing the power button on the sound bar.
Any ideas?
Brother, me and you are/were in the same boat.
I'm soooooo not a speaker guy too. My brain just isn't wired for how speakers work. I replaced my factory speakers with Wet Sounds but the factory Polk head unit (and amp if it has one) was way underpowered. I'd have the volume turned all the way up and it sounded like the speakers were only playing at like 30%. It was bad. I purchased a 4 channel amp and had to send photos to my brother (just like you posted) to get is input about how to wire it up.
Over all, it wasn't bad. I had to cut the speaker wires coming out of the Polk head unit and run them to the amp (one speaker per channel so super easy) and then run RCAs to the amp.
Franky, I was out of my comfort zone but I did it.
If the factory Polk head unit (or amp) are bad I recommend you get a 4 channel amp and run the speakers thought that. I can send you photos of my install.
