Buckeye Fan
- X
Does the 212s have two batteries? Is a 3rd needed?
Comes with 2 I haven’t had a need for a third yet been out all day with our set up and haven’t ever drained the house
I have a 2018 212 Limited S. I kept the stock Polk speakers but I have a dedicated amp powering them. They sound pretty good. I have four 8" tower speakers powered by another Amp and then a wet sound 6" powered Sub. I would have gone with a larger sub but the placement is pretty limited unless you make some serious modifications. Where will you put your 10"sub?
If I'm not mistaken, the 2019 and 2020 212(s) have 6.5" Polk DB652 black colour scheme in the bow and cockpit. The rear swim platform speakers are probably Polk DB522 5.25" units. The 2018 had DB651 I believe with a silver/gold colour scheme.What speakers come in the 212s? Are they decent enough to add an amp to?
No I upgraded the stereo. I’m running an amp dedicated to the stock 6 Polk speakers, an amp running a wetsounds sound bar and an amp running a 10” Polk sub I installed on passenger side. All have run all day on the single house battery without draining too low. I do have a dual bank charger I’ll plug them in when on the trailer and in the garage. We were on the water for a 3 week lakehouse vacation this year though and never plugged the charger in the entire time the boat was in the water and battery performed fine.Are you running the stock stereo? What speakers does the stock setup have? Haven't picked ours up yet but doing 2 Rev 10's and a 10" sub, unsure if ill need to upgrade the factory 6 speakers or not?
I just got 6 new JL speakers to replace my stock Polk. I'm adding a JL amp as well. Where did you mount your amp? Where did you run the wires? Do you have pictures? TIASo after 6 years with my SX210 I bought a new 212 Limited S sooo....its time to start the upgrade process all over again. I tried using the search feature but can’t seem to find any build threads for stereo upgrades. Looking for advice on what equipment everybody is using, and mounting locations. Looking to do it in phases. Probably start with a 6 channel amp, possibly adding sub at same time. Then upgrading speakers. Then adding second amp and tower speakers.
Thanks in advance!
Did you re-wire your original speakers? Also if you used a dedicated amp for the 6 factory boat speakers what did you go with?No I upgraded the stereo. I’m running an amp dedicated to the stock 6 Polk speakers, an amp running a wetsounds sound bar and an amp running a 10” Polk sub I installed on passenger side. All have run all day on the single house battery without draining too low. I do have a dual bank charger I’ll plug them in when on the trailer and in the garage. We were on the water for a 3 week lakehouse vacation this year though and never plugged the charger in the entire time the boat was in the water and battery performed fine.
