David Decker
- Atlanta, GA
- 242 Limited S E-Series
I used liquid nail and C clamps to attack 3/4" MDF to the front. Where I could anyways, I did not add wood behind the table mount for 2 reasons 1 so I could remove the speaker and get to the bolts if I ever needed to remove the mount and 2 because there is already wood backing the mount.Of coarse the speaker screws bite into it as well which helps I also glued the bottom and front side in. Then I was able to glue and screw the rest of the box to those pieces. Because of the angle of the face and the bump out in the bottom it was hard to get the proper air space, even had to add a second layer of MDF to the bottom, but in the end I ended up with approx. .76. I planned originaly to use the starboard side but could not figure out how to do it without loosing the ability to get the cooler in and out.@ChrisP - that looks really nice! I somehow pictured the sub on the starboard side, but it looks like you placed it on the port side. Did you use a "backing ring" behind the sub? I didn't put one in initially, but I am thinking of adding one so the screws have more than fiberglass to bite into. How did you attach the MDF box to the fiberglass front?
What is that white disc with the perforations, about the size of a quarter, just below the rear speaker? I saw it on my boat the other day and it looks like some kind of sensor. It has 2 wires coming out behind. A mic? Temp sensor? Gas detector?
I added an 8" there and there was plenty of room. See pic below. The cables are not in the way.I was wondering if it would be possible to also mount a sub on the starboard side
to the rear of the throttles? I will are the depth is there but wondering about the routing of the cables? This would allow me to run a pair of 12's...
I was also curious about adding a 6.5" coaxial in the upper combing area?
