SamCF
- Greenville, SC
- SX192
Most of the -20 blue washer fluid is 30-33% Meth, a cheaper alternative.
If you're not tuning more aggressively for the meth you could probably get away with running that.
What size tank do you have? I use to run a 1 gallon tank in a road race car with the smallest nozzle on an AEM kit, in a 25min race it'd use over half the tank (20-25min). Figure the car was in boost for a majority of the time. Depending on when you have this start to spray it may use it very quickly with two nozzles. With the medium nozzle I had to a 2 gallon tank.
Do you have a wideband o2 for monitoring? If you're spraying a bunch of this keep a close eye on the transition point of the spray. Expect a fuel ratio change.
Installed a 1 gallon tank. I'll just carry an extra jug, but I don't think I'll need it. It's only going to spray from 8000 rpm up.
I ran washer fluid on other applications, but really want the 50% meth on this application. The stock fuel system is maxed out past 8300-8400 rpm with this charger wheel. At that point it will be beneficial to add the methanol for fuel and cooling. I do monitor AFR, it runs 12-12.2 up to 8300 and runs 12.5-12.7 at 8600 rpm. Thats why this is set up to spray only at high rpm. I don't plan on spinning that high again, but the added fuel/octane will make me feel a lot better about it.
I had a PowerShot to add fuel up top, but the transitions in its tuning zones were not smooth. The run yesterday was stock fuel system with Dean's tune. It didn't spin high enough to see if it would lean out though. I have a fuel pressure regulator and high volume pump to install, but I don't want to throw everything at it at once.
