FSH 210 Sport
- Tranquility Base
- FSH Sport
I still suggest you check the fuse first, it takes about 10 seconds. It is one of the corner fuses. Otherwise debris sticking up your float is a great second.
Respectfully submitted, if the fuse was blown I don’t think the pump would work at all. The posted mentioned that the bilge pump worked when he manually turned it on. So I’d think there is only one fuse that protects the line to the bilge pump. I definitely could be wrong on that since I don’t have a single line to look at.
