The 2015 24x issues thread...
I never hear mine. If you ever have a question about its output, just open the engine compartment and look for water. But if your boat is sealed up and the drain plugs are firmly set you shouldn't be getting much water in there anyway.
The bilge on the 15's is set to auto every time you start the boat. Also if you leave your battery switch on the bilge will cycle every few minutes for a split second and flash all the led's in the boat. Even with the keys off. The pump is very quiet but if you lift the engine cover you can hear it. I have never had enough water get in the bilge area to activate the pump. It seems any water that splashes in the boat is routed out through the hull drain. You could just pour some water in the bilge area with your pump on auto just to make sure it is working.
I think the flashing LED's was on the early production 2015's. Mine does not. I had asked the dealer about this and they said it was fixed on new production models.
"Fixed"?
I kind of liked that friendly reminder to turn off the batteries. Flushing out the engines, late at night, and a few (too many) beers in me I have a growing record of forgetting to turn those things off.
My LEDs flash if I leave the battery switches on. I never thought they did but I was out there in the dark once and they did flash but it was about 5 minutes between flashes. You guys need to find out where the water is coming from. We tow wakeboarders and tubers all day and last time out there was no water at all.
It wouldn't be hard to drill a small hole in the very back lower corner into the ski locker to drain if you keep having issues with water getting in there. Mine was outside during one of our many down pours a couple weeks ago and only had the shipping cover on it and got 5-10 gallons of water in it but none in the port storage compartment. I can't wait for my Deluxe Premium Mooring Cover to get in so I don't have to worry about it anymore when I leave it outside.
I have had mine since May of 14' and have only ever used the shipping cover (waiting until it wears out before I spend the cash on a new cover) and have never had water get inside. Is this a common occurrence with the shipping cover?
My lights flash too... Couple other things I've noticed... tons of loose screws. The head compartment door almost fell off. About 75% of the screws that hold the helm door on are stripped. There are quite a few screws throughout the boat that just don't tighten and feel stripped. Also, the Connext is far too bright at night- even in night mode (which I think should have an auto setting) and dimmed all the way. I have to throw a towel over it to see anything at all.
@morgro269 - How many hours do you have on your boat? I know when I did my 20hr service I had the same findings. My dealer told me that besides an oil change that is one of the major items on your first service. They highly recommended blue loc-tite. I brought all my loose screws to their attention and made them repair them, with a service record for it. (just in case there is a repeat).
As for the Connex when you turn on your nav lights the display should automatically dim for you.
INITIAL MAINTENANCE SERVICE:
According to Yamaha, and as stated in the 2015 Owners manual (starting on Page 140 for 24 foot boats) the FIRST SERVICE is at 10 hours - not 20 hours.
Then every 50 hours or Annually thereafter.
Please know there IS a typo in this chart, as replacing the oil filter is not "checked" for the 10 hour service. But this is a typo that is being corrected.
Y'all have a great boating weekend coming up - Mikey Lulejian - Lake Oconee, GA
@MikeyL - yes sir you are correct. I was told 20 hrs by my dealer and didn't do mine until then. However it is suggested at 10.
The only issues I have with my 2015 24'er are some gelcoat cracks. I'll fix all my wonky stripped or not tight screws myself. The boat runs like a scared rabbit, starts right up, rides decent, and has comfortable seats. No list to my boat that I can tell and it takes on minimal water. For a bit, I second guessed my decision but have totally warmed up to the boat after seeing tons of the same issues that Yamaha has in other, more expensive boat brands. I am kind of smitten with the new fsh though since I'm more of a no frills guy. Read: Less to break.
I bought the cobra kit from Jeff since the mrs can barely drive the boat plus I really think that tying the two nozzles to the keel is a good idea. And I think it will crispen up the steering at speed.
Sooooo, I guess I am going to revive this thread... I remember reading this issue somewhere else and I am unable to locate the thread.
I was out on the 4th and we anchored for about 3 hours. I had the house battery "ON" listening to the radio. The start battery off was "OFF". When we were getting ready to leave and I started the engines, the low battery alarm went off. Both batteries were at 9V. I could start the batteries without turning "ON" the parallel switch. The question here is, why would the start battery go low if it was "OFF"?
It must be hooked up wrong.
Its not low. The Connext screen only shows the voltage of the house battery. I've spoken to my dealer and Yamaha and they know about it and basically told me tough. They know its displaying wrong but they aren't going to fix it. I'm kinda pissed about it.
REALLY!!?? What a bunch of pricks with ears...SO basically, unless I put meter on the battery I will never know what the start battery is doing. WOW great way to feel secure.
Basically yea. I've tested and tested and sent all my info to Yamaha and they acknowledged the problem and said they had no intent on rewiring the boats. I also got my dealer involved and Yamaha told them the same thing.
Hey, it's not like the boats cost $60K or something. . . . .what's a few glitches for such a cheap boat?
I'm pretending I haven't read any of this cause both of mine usually stay around 12 volts and no problems so I have my eer muffs on right now
Ok, please clarify this for me. When you said that the "Connext only shows the house battery" are you referring to the home page? I'm asking because I'm getting the correct individual readings when I go into the diagnostic page on the Connext.
I will have to check again. I think the diag screen will show them but the home screen doesn't but Im not positive about the diag screen.
