Master-Spud
Jetboaters Commander
- Plamondon, Alberta, Canada
- Nautique
- Other
Lol, no but that would be funny.. I have the same insert, but the two people that had problems have 2010 or newer models with the same GPS speedometers we have, I assume they had the insert included in the instructions, but you know what assuming gets you. I take it yours powers up as expected? (I hope)
OK, that's two people that have had problems using power from the original speedometer. I can run power to a fuse box under the helm but I can't decide how to keep PP from being powered on all the time. I could run it to a switch but there has to be a better way. I need some ideas from people smarter than I am.
Holy Crap $340!!!! I just did that for 60 bucks, but I might have had 340 dollars worth of head aches....lolAs far as switched power, I think once you get a few accessories you need some sort of fuse block that has a switched power option.
Here is an awesome one, controllable via iphone http://www.motobrain.net/the-motobrain-pdu/
But there are much cheaper options...
I plan on just following the specific instructions that came with the one page supplement in my instruction manual.
To power mine, I tied into a switched power wire on the back side of my key switch. I believe it was yellow (double check with a meter). Perfect Pass only powers on when the key is turned on, and no wake mode works as always. 2 full seasons with no issues at all.
I must have been lucky. My system took a couple hours to install and was very easy. I did spend quite a bit of time on the water adjusting my throttle cables though. I remember that being an annoying task. But once dialed in, I have not had to touch it.
