- Royal, AR
- SX
@firecap797, where will you install the amps?
These are small amps so they do not need huge wires.
If you install them near the battery the power cable can be smaller, shorter and less expensive but you will need to replace or extend the speaker wires.
If you install the amps in the helm you will need to run a pair of 8 gauge power cables for each amp or a single pair of 4 gauge wires that would split to power the two amps. Then you could reuse or upgrade the existing speaker wires at your preference.
I have not yet decided where to install my pair of amps. Either way I will use two pairs of 8 gauge wire. I know lots of fancy marine wiring options exist but I have had good luck with and will continue to use 8 gauge copper THHN wire from an electrical building supply. I will terminate the ends with ring connectors with shrink tubing seals. I will add a BlueSeas fuse box with ground bus near my battery switch to use as a power source.
