I would find your accessory fuse holder, typically mounted on the wall near the battery, and follow the wire to the battery. My bet is it got attached to the negative post on the battery. This happens a lot since the red wire is in and completely covered by a black protective sleeve which folks take it as a ground wire.
Thanks Andy. Both batteries are in good condition. Had both tested. Although one is gel and one is wet cell now so I'll go to the store and get two of the same types (didn't realize not to mix gel/wet cell). But here's a few photos. I believe I might have figured out what's wrong. I hooked the one jumper cable (the bigger black one) from negative on BAT 1 to the negative on BAT 2. I believe to run this correctly in parallel it should be from positive on BAT 1 to Negative on BAT 2. I'll post a pic or two. Love your thoughts. Thanks again Andy.
Andy thanks! I found the problem. It was the inline fuse. Its a small 20 but when I had pulled it out, it didn't look popped. So after troubleshooting a bunch of other stuff, I finally went back to the fuse, pulled it out and replaced it. And everything came back. Lesson learned? Even if it looks fine, replace it anyway.
Hi guys, any update to this thread regarding the cause of the 2 bad SBT motors? Blown SBT motor here after a year. Dont know the cause yet but will report back
