Those wanting the wakebooster package for 19ft boats
Maccam26
Winston-Salem, NC
Here’s what the wake looks like on my 19ft SX190 without riders. I’ll report back on how things go in this thread when I get my wetsuit lol. I was impressed with how clean the wake looks, not big obviously but pretty cool if we can muster the technique. I have a Slingshot Coaster 5’3 board that we will be using.
Looks like some massive ballast bags on transom also. Might want to list your add ons so people don’t assume that wave is only from a wake booster. And that wave looks awesome though to surf for sure! Have a fun summer
Yes this is why I called the title “wake package”, it comes with 2 - fat sac bags that hold 200lbs of water each for 400 lbs total, the tsunami pump to fill them and the wakebooster.
What does the wave look like with both bags on the same side?
I don’t know as I’m going to leave them as is which is what the Yamaha engineers figured was best. I don’t want to ride listing to one side as my wife will be driving. I also like that the dog bones I drilled are securing the bags and not ropes etc..
also I have 1 or 2 accounts of people that own these bags that said the Yamaha proposed way is best.
Considering dropping a bag in the ski locker. It will help sink the boat with no listing or raising the bow I think. Don't know if it will counter balance the transom bags or if it make a better wave.
forgive me for my ignorance here, but does all this added weight put stress on the engines? seems like it would.
i'm certain it does but the weight capacity on my boat is 8 people, so adding 400lbs of ballast to the back plus 3 people on the boat is still within capacity in my books, it's just putting a lot of the capacity at the stern. I won't be putting more than 3-4 on board with the ballast inflated.
I think the Yamaha engineers sold that package as a bare minimum. You may even be able to get ropeless, but you'll be stuck in one small sweet spot of push. Prepare for the money suck... :)
Here's my progress with surfing on a Yamaha:
yeah i understand, worse case i'll be towed with a rope... i really don't have a pipe dream that this will be like a surf boat. I'll try to become very proficient at technique ... i'm just tired of falling off the wakeboard at 18-21 mph haha some of those hurt
If I add the ski locker sack 750lbs + 400lbs transom + 3 people, one will be surfing I feel good about. even if it was 4 people plus think I would be ok. Of course that doesn't include the weight of gear, gas cooler et cetera.
IMHO no - running the engine at 7000rpm while cruising at 35mph or while pushing a ton of ballast through the water at 11mph is the same amount of work. Remember, this isn't like loading a truck down and having external pressure between driveline and the road.
Besides, these Japanese built motors WANT to rev high and throttle up and down. They were built for that sort of use, whether in a motorcycle, jet ski, or jet boat, they're meant to work under those conditions and at those RPMs.
Last season on my 2019 AR195, the best setup I found to go ropeless was:
650 Gantlin bag on transom, centered
200 cube surf side on rear seat
200 cube on bow floor
About 9.5 mph on Ridesteady GPS
Coaster 5’3” board
One adult driver and two kids in boat
YMMV, but I was able to go ropeless all day long using that setup.
Coaster 5’3” board
And you could still get the surfer out of the water with that setup? My fear is I have 70hp less, not sure how much less torque and the 155mm pump vs 160mm pump, so not sure i can add 650 and still pull someone up?
Yep, the 195 doesn't have any problems getting me out of the water. I'm about 185lbs. Not sure how the 190 engine would do - you'll have to ask around about that.
That setup was the result of lots of trial and error over the summer. It works for me, my boat, and my lake. You'll need to do the trial and error for your specific situation and see what sticks. That's the thing about trying to surf behind these boats - it can be done well but its not a turn-key solution. Keep trying different things and be patient.
One more note - this summer I plan to get the kids surfing. I'll start with only the 200lb cubes and hopefully that will be enough for their small weight. Will save me time from placing and filling the big bag.
good stuff @gallobg , i'll try to see how our 190 performs with 400 and a few adults on board and go from there. maybe instead of adding 650 directly, I can get one, two or three more 155lb cubes from fatsac. I was thinking adding 2 more 155lb cubes on lower swim deck each side and 1 155lb cube in the bow.. that would put me at about 465 + 400 from the yamaha kit... the 2 extra on the lower swim deck could be tied to the one on the top swim deck too
4 cubes on the back would equate to approximately the 650bag, the 155lbs in the bow to lower it a tad.
Here's my only comment - all bags are a PITA to secure on the swim deck and they get heavy fast (especially when they fall off the boat, ask me how I know...)
But seriously, if you are going to get extra bags, have a solid plan ahead of time for how you are going to secure them down. There's just not a lot of tie-down points on the 19 series swim decks, and the fore-aft width of the platforms is limited. That's why the Gantlin bag is popular, it has a custom shape to fit onto both of the upper and lower swim decks. I have seen other people use different bags on the 19' boats - do some searching here and look at all of the pictures that you can. Maybe you can try one of the "long and skinny" style of bags instead of more cubes? Might fit the geometry of the lower swim deck better.
@gallobg i get it but remember i have an "SX" no tower, so i need the middle clear for my tow rope...which is a whole other ball of wax lol.
Maybe the 2 extra go on each corner back seat in the boat , then they don't need secured, and act as 2 people onboard. Just thinking out loud.
Like you said, keep trying til it works for your circumstances, appreciate all the input
Even if the bag is tied center, you could still put your surf rope on the cleat behind it. Just attach it before you fill the bag. You won't hurt the bag by having the rope against it - I talked to the manufacturer when I bought a floor bag and he was like "its strong enough to have dogs walk on, don't worry about it."
This is great to know thanks for input!!
