I have the same issue on my 242x e. Cant get speed above 10. Did you fixed it somehow?Will make some of these changes today and see how it works out. Thanks for the input.
Thank you for the reply. I will put more ballast at the front. Good idea with anchor locker. I have wakebooster but Im thinking to by wake Wedge, waiting for your compare videos and foto of soundproofing.Yes. Key is ballast in the front. Or lots of people to move up there. I bought 35 pound and 50 pound ballast bags from Lead Wake online. Really well made and easy to move around. I put four 35 pound bags in the anchor locker so they are out of the way. Then I have a fifty under each front corner cushion. Then I move another two fifty pound bags around as I “feel” the boat during setup depending on passengers etc. This all works really well and allows speeds up to 13-14 so you need to pull it back a little actually! On top of that I am getting those speeds at 6000-6500 rpms versus before I was at top end 7500+ which I was really uncomfortable with. Plus I hate how loud the boat is, especially at those rpms. Amazingly quieter at 1500 rpms less, although still too loud. I was just installing soundproofing today. Hoping that helps as well. I have some videos of wakesurfing over past several weeks with Yamaha wakebooster as well as the wake wedge. I prefer wake wedge but either will produce a rope less wake to surf. I will post some comparison videos when I get a chance. Any other questions, let me know. Not an expert by any means but I’m learning. Also, check out Wake9 on YouTube. A wealth of knowledge if you are trying to wakesurf behind any boat. Teaches about using an in inclinometer to set your boat up for a consistent wake for surfing. I’m working on trying that next so it is more consistent. We will see.
This video did a nice job capturing the overall size of the pocket we've created with the Wakebooster and extra ballast, I'm 6'3", 180 lbs. Not bad for a second year surfer in MN and we're getting great versatility out of the 242x for all our boating fun, including a good wake.
<iframe width="560" height="315" src="" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
Can you post a link to a similar one off Amazon (correct size). Thanks.Because I don’t want to be trying to tie a knot with Yamahas short, low quality rope. That’s a pain to do.... extra climbing carabiner... duh. View attachment 123337
Thanks for the suggestion. Surf setup added to signature.That looks like a very clean wave and plenty big enough to have fun with !
how much ballast are you running ? You should add to your signature line what your set up is so people can always see it,
You can also just use any size carbineer and just snap it to the thin cable that connects the booster and the lock pin. That's we we do and it's much easier to attach and detach because of the flex of the cable and size of the cable vs. carbineer opening vs. the thicker grab bar on the booster. Just a thought.Can you post a link to a similar one off Amazon (correct size). Thanks.
