- Naples Florida
- SX
You need to look at your battery supply, if you've got multiple batteries you can go with 2 pumps. One 1500gph is a reasonable pump for a 23' boat, two 1500gph is a little overkill but good peace of mind for a few hundred extra bucks.Sorry for the hijack...so if I wanted to upgrade my pump, are you recommending a 2000 gph and just remove the existing one? That would be the easiest thing to do I would think. Thanks!!!
When you upgrade the old pump you will need to run a bigger discharge hose and install a bigger thru hull fitting for the hose.
Note --- those 2000GPH pumps are not for my boat, they are going into another 33' Intrepid.
