random thoughts... so if you had a 2009 or a 2011 model it wouldn't do that ? sorry about your luck? that's the dont giv-a-shit answer!!!
110,140,160,180 engines should all come out of the hole initially with very little cavitation, obviously lots of variables...
The boat should jump out of the hole like a shot if everything good... something wrong in the tunnels and/or the pumps.... bad pumps work kinda OK at speed but really suck out of the hole... ask me how I know LOL.... prolly feels a bit like a bad clutch or automatic trans... slips a lot till ya get moving but if you baby it once your going its ok >
Im coming up on a couple thousand hours of salt water operation in the last 6 years and I've broken/worn out every part of the jet pumps... twisted splines, snapped shafts, took out bearings, split nozzles, sheared the nozzles and buckets off, bused out the stator veins, bent impellers, bad mid bearings, leaky cleanout plugs, had to reseal the tunnels a couple times... had the transom plates come loose... shattered the jet tunnel bulkhead. I've used aftermarket and oem parts and developed a few of my own improvements, the first being the jet tunnel bulkhead that looked like and after thought and built by a 12 year old that didn't know the first thing about engineering and others around the stator housings and the nozzles...
I have two BAD setups on my boat right now, one missing half the stator veins but everything else ok and that side don't start working at all till 25 mph just cavitates and no thrust... the other side the pump is ok and the stator is ok but the mid bearing is sucking air... so that's all bubbly but gets me up on plane if i baby the throttles... its ok from 30-45 or so then it all falls apart as i get up around 9000 rpm and if I go WFO 10,500/7200 shaft RPM on the MR-1's the cavitation returns and I start slowing down... I am running the old pumps from the 135 two strokes that only turned 6700 shaft rpm...
Im building new hybrid HO pumps to solve the problems... a little bit of machine work , make some studs, plug a hole and weld some bungs in the the screen covers, problem solved for me...
you should be good with a "properly" functioning stock setup... My experience is that SOLAS impellers can reduce cavitation over stock but aren't as tough... you should be able to roll the throttles into WFO from no wake speed and jump on plane without any significant cavitation
View attachment 189721View attachment 189722View attachment 189723View attachment 189724View attachment 189725View attachment 189726View attachment 189727View attachment 189728View attachment 189729View attachment 189730View attachment 189731View attachment 189732
