The. Port eng has a low cyl. So I need to pull the top half inspect and replace what is needed minamum three pistons and have the cyl s. Bored.Sorry @piper84 , I haven't rebuilt yet but had the same question. Do you have to do 1 engine or can you do both? I would consider a cheap engine lift from harbor freight and pull them out. A lot easier to work on, paint the workbench white so you don't lose parts, and enjoy the fun. Keep me posted and PM me if we can talk through the steps. Great boat!
Good to know that It can be done. Worked on helicopters for 18 years but marine engs. Are a little different. Use to working upside down sometimes! Going to give it a go.You can do it in the boat. It is just uncomfortable to be leaning over for a long time. If you strip most of the stuff off the motor can be lifted by hand.
Not yet but I bought the boat knowing one eng. Needed some work. I suspect it was an over heat issue. The exhaust riser and water jacket was almost plugged up with scaling restricting water flow. I made sure the motor did turn over, started and ran before l bought the boat. Want to be as less evasive as posable with the job as I can. Will keep you posted.You will be good. It is a very simple motor. Did you find the cause for failure?
Thanks did find the link and downloaded the manual. I figured the head had a spasific torque sequence and in few stages.Download the manual for the LS2000. If you cant find that then look for 97 gp1200. Same motor.
