piper84
- LS
I pulled the cyl head off and found damage on aft piston that I could not see otherwise also elongated Cyl wall in spots. This is the cyl at 90 psi comp ck even lower when wormed up. I am replacing all three pistons and ordered a remanufactured cyl head. Was recommended by supplier to also rebuild the carbarators. Dammage to piston side was on the exhaust side most likely due to a lean running carb. So I’m going to rebuild all six carbs and replace oil lines.
