I know You know
- South Florida
- FSH Sport
You have the front wheel drive model and still had the all season highway tires on there? If so then I totally see you having trouble. I ditched the mini van tires with some nice meaty AT's. It also helps these wranglers are torque(y) little monsters down low due to them being setup for crawling rocks at low speeds. I've regeared as well to make sure snatching things like this boat out are done with ease. There are some ramps I've been to where 2wd is not recommended regardless how big of a truck you have. I've seen some 2wd full size trucks spin their tires getting smaller boats than mine out of some ramps and need help. Normally a couple people in the bed will do the trick, but have seen some need to get a tow strap out.
It definitely takes some thought going into some of these. There's one near the coast I grew up on that my parents 4wd Expedition has a hard time pulling a 2000lb boat up. For ramps like that I'll just avoid it. I've seen so many trucks struggle there over the years.
Like anything be smart, take your time, and if you don't feel comfortable....don't do it. I keep that all in mind I shouldn't have an issue. The ramps I'll be using around here are fairly flat.
Yes you are correct, I had the regular street tires on it, I figured with it being FWD we should not have an issue but I guess I was wrong, got to the point last year that I was launching with my Explorer and I was having my buddy retrieve my boat with his Chevy 4 WD. Now I should not have any issues with my new set up. BTW what are the ATs you're running on that good looking Jeep?
