InmyElement
- Upstate, NY
- X
Whenever we go through a wake or heavy chop the joints of the tower creak...I believe. I've checked the base plates and they are fine. I have the 2016 tower with the 3 bolts on either side and the pivot joint. I'm planning on taking them a apart and using white lithium grease for the joints with the metal to metal contact. I have to lower the tower every winter for storage, so I usually give a spay of WD-40 around the joints and put antisieze on the threads of the tower bolts. Any other recommendations or insight would be appreciated.
Thanks
Thanks
