BlkGS
- Melbourne, FL
- SX
I would like to see at least a 50kwh in a truck. The Jeep has a 17kwh with 15 usable. 45 usable should give me over 75 miles normal and 30 mile towing.
The problem is where does the battery go? I don't think there is much room on a standard chassis. Maybe tuck it under the bed (like where the spare goes), or hell give me 6" less of bed space and put it in the bed. There is no way a battery is fitting under the hood, plus it would get too hot from the motor.
Au contraire, if you only had a small generator upnfront, you could bolt in a bulkhead that'd put the generator on one side, and a battery pack on the other. And since it'd be relatively small, you wouldn't need to do anything too crazy to make space.
But yeah, you could make a flat pack that fit in the bottom of the bed that was an inch or 2 thick and nobody would ever notice.
