BrentM
Check your manual. Your profile is showing you have a Sea Ray, and if you have a Yamaha, it'll be in the manual about when to check it.
10-15 minutes may not be enough, as evidenced by your statement that it's correct when cold. Mine should be checked when warm, in the water, and I would want it to be middle to not quite full at that point.
Yours may be different, but it's in the manual somewhere
The reason for my question is that the owners manual states to check without resting after running.
However, the service manual states to “rest for 5 minutes or more”. Because this is a dry sump oil system, the rest vs no test matters on oil level.
