Amar Nanduri
- SeaDoo
- Challenger
Hi Guys. Yesterday was my first experience ever in taking out the boat and getting familiar with the controls. It is my first boat ever. The boat rocks pure and simple. Putting the boat in the water from the trailer is not that much of a problem. The real problem was in getting the boat back onto the trailer. The wind is not much help either. It took me an hour and half and that too with help from a couple of other boaters to finally get the boat onto the trailer properly. The boat was slipping away from the trailer to the side as soon as it got halfway onto the trailer. It got knocked up a few times also.
There should be a better way to get the boat onto a trailer without issues. The first thing I thought about was the Trailer Guides at the back of the trailer. The boat is wider than the trailer it is on. So I will need guides which can accommodate the boat. What are the best DIY ones out there in the market ? Something that I can easily install by myself. Also are there any other things that you recommend I purchase for the trailer so that the hull does not get damaged during loading / unloading the boat from the trailer ?
Also which oil do you recommend to grease all the joints on the trailer. The tongue is stiff and requires quite an effort to swivel it around. The springs look like they badly need oil. I am basically looking for things that will make my life easier in trailering the boat. Thank you for all of your help.
Best
Amar Nanduri
Best
Amar Nanduri
