captainhook
- Southern Maryland
- Limited
Thanks. My issue is that I use so much electricity it is very difficult to generate it all. My house is entirely electric (heat, water heater, dryer, stove, etc.) as there is no natural gas line in my area.I bought and install ours in 1995/96 it is a 24 v system with a Trace 4000w true sign wave inverter and about 7 days of storage in the batteries, depending on usage. Being off the grid, I designed the system by calculating our daily usage of everything we used. Refrigerators, with auto defrost are big users and that is why we still use our Sunfrost 22 years later, although we have added another frig. and freezer to the loads since. Transformers plugged in walls will use power 24/7. The television uses a lot. There was no internet around when I did this, but there are sites with information on this topic.http://www.leonics.com/support/article2_12j/articles2_12j_en.php, is one there are others. Currently, my system inputs have not grown as my system demands have and is undersized for the loads of the pool filter (summer) and all the circulators and outdoor boiler (winter), but it helps out and I do have a quiet backup if the power grid goes out
To start, break down your monthly demand into daily demands and then from there you can calculate your system requirements based on average hours of daylight or wind speeds for your area and the hourly amp/watt outputs of the pv/wind devices used.
SunCommon has a big presence in our area, I have seen many roofs covered with panels recently installed.
I need an enormous system which isn't anywhere near cost effective, in addition to still not generating sufficient electricity to be off the grid. Even with subsidies in the form of tax breaks, the quotes I've received are $60,000+. That buys me a ton of electricity at 13 cents per kWh.
