tabbibus
- Lake Lanier, GA
- 242 Limited S E-Series
For now, I just went ahead and got the Clarion XC2410 - I'm only in it for $99 bucks, and from what others are saying, it'll still sound better than stock. Then I think I'll budget next year for the rest of the setup like I want with some higher-quality components, and I can just sell the XC2410 and/or reuse it in one of my other vehicles. This should get me by this season, and I can work on upgrading the stereo system during the off season. I'd probably still have time to tackle it before our scheduled trips this season if I really pushed hard, but time's getting away from me fast, and I don't want to risk having things all torn apart and/or doing a rush job just to try and finish in time. Plus it gives me a project to work on over next winter to fill the time before Summer 2020.
What gauge wire should I run for power to the amp? The power leads from the amp look to be standard 18/20 gauge wire in the pics from Amazon, but I've seen posts on here where folks are using like 8 or 10 gauge wire for power. Shouldn't you just match the gauge of what's coming off the amp, or is that not sufficient? Seems like you could only pass as much current as is allowed by the smallest pipe in the circuit, so even if you're running 8/10 gauge off the battery to the amp leads, then it steps down to 18/20 gauge at the amp leads, you're way overkill.
Okay, I wired up the XC2410 this weekend and decided I want a sub, so I'm returning it and getting the XC2510 so I don't have to wire up 2 amps. Probably way overkill for the Polk DB652's that are in my boat, but at least I'll be in good shape if/when I decide to upgrade those. Granted, I may end up deciding to go with a better/more expensive amp at that point too, but I just didn't want two amps under the helm.
The wiring job was pretty straightforward, I'll post up some pics once I get the XC2510 in next weekend (the install process will be identical, I just need to wire up the sub as well). Also, I just did a test run with it this weekend and ran some speaker wire across the cabin of the boat from the battery for power, but obviously when I permanently wire it, I'll be running some quality power leads from the battery and feed it through where the rest of the OEM wiring runs.
Did you install a sub yet? Trying to decide where it will fit in our little AR195s. Also, did you run a fuse block?Sorry for the delay in the update - I started another thread in this forum about tuning the amp after the install, and I didn't update this thread. I received the XC2510 earlier than I thought I would, so I installed in on Wednesday night after work - HUGE difference from the XC2410. Once the low frequencies are split out and thrown to the sub, it's amazing the difference in makes in both the sound quality and volume levels on the DB652's. I turn up the volume on the GR10BT to around 30, and it's almost uncomfortably loud, and if I have the levels on the amp adjusted properly, there's little to no distortion. (The other thread that gets into the amp tuning on this forum is here: https://jetboaters.net/threads/question-on-amp-wattage.21539/)
The price difference between the XC2410 and XC2510 is around $190 ($99 versus $289, plus add in a few more bucks for a sub if you don't have one), but given my experience with the difference in the sound from both amps, I'd still say it's worth it and still a relatively simple and inexpensive upgrade compared to the higher-end amps and speakers from brands like JL and Wet Sounds. Is it a comparable upgrade to the higher-end equipment? I would say probably not, but that's not really what I'm expecting at this point. I just wanted decent quality sound that I could hear over the noise while underway and at a little distance from the boat when at anchor. This upgrade fills both of those qualifications, and I'll be happy with it for this season.
It would be interesting to hear this upgrade versus a full JL or Wet Sounds system in an AR195 side-by-side. I have no doubt that a system like that would blow mine away, but with regards to the sound quality, are we talking night and day difference, or just nuances? Also, I'm sure my sub's performance couldn't hold a candle to some properly-mounted subs and/or tower units (if they can go up there anyways).
At any rate, I'm very happy with my purchase of the XC2510. It doesn't break the bank, it provides me both decent quality sound and volume, it's reasonably easy to install, and it fits perfectly behind the helm.
