Wow
@Compatico , i need an “over my head” emoji for your second paragraph. Thanks for the information/education regarding the remaining paragraphs.
I attribute my “discovery” to dumb luck. I happened to install the right speakers powered by the right amp in the right spots.
You chose well though...bigger is usually better.
I just switched the 8”s from a 2 channel (150w per) channel amp to a 4 channel (117 per) amp to accommodate a new pair of tweeters on the swim deck. If this noticeably changes the bass response on the swim deck I will switch the amps back.
I doubt you'll notice much difference in the sound output of the 8" speakers, but the tweeters will fill in more treble and you might perceive a loss of bass output as the highs will tend to balance out the bass. If you tune the bass/treble a bit, you can probably find a nice blend of highs and lows.
As for power output, once you get to a solid 20w RMS the rest is usually just a bit more volume/overhead. Speakers are
much more critical to sound quality than amps, contrary to what the salesman will try to
sell tell you. An inexpensive $100 amp will make $1000 speakers sound great (within reason). But a $1000 amp will not make $100 speakers sound great, since speakers do 90% of the work.
When it gets to big speakers sounding better with more powerful amps, a lot of it has to do with damping factor, rise/fall rate, and the ability of the amp to push the speaker cones with controlled output. That's why a solid speaker with a big heavy magnet and voicecoil combo needs some "oomph" to get them thumping. A whimpy head unit with a few real watts of power won't get them moving properly. But a decent 10w or more will get it done. Once you hit 10-20 watts of power, jumping to 100 watts only gets you 6-10dB louder volume because perceived volume is a logarithmic scale and power demand climbs quickly past 10w. Contrary to what you might think, volume is not linear, so 1w to 10w to 100w of power is not as dramatic as it might look on paper. A perceived doubling of volume of 10dB requires 10x the power to achieve. This all assumes 1 speaker. With 2 or 4 or 6 you can get that perceived volume level to increase a bit faster, 10x more power gets you 13-15dB more volume, which isn't that much beyond a doubling of volume.
A well made 50w amp will sound just as good as a 100w amp and at peak volumes many people would be hard pressed to hear the difference. If your 50w isn't enough volume, you need much more powerful speakers and amps, and more of both, to crank up the volume - again assuming the amps and speakers are all equal quality. None of this applies if you're going from crappy tin can speakers and low output head unit, to 100w/ch amps and good sounding speakers like JL or Wetsounds.
With sound quality, you generally get what you pay for. Great sound isn't cheap, but good sound can be had for a reasonable price.
