Cambo
- Long Island
- 242X E-Series
when you took the lid off the air box did you see chocolate milk looking oil sitting in the air box cover ? This usually happens due to the additional fluid being introduced and the breather spits it out into the air box. The other thing that happens at idle you will see steam coming out of the pisser. I think the reason the breach occurs is from cavitation, as the aerated water flows through the cooling channels it does not cool properly causing the aluminum to fail.
