Wet sounds tower speakers LEDs
toddgray519
I have a 2023 222x could someone tell me if the tower speakers are pre wired for LEDs like the other speakers on the boat if so how do you access them and attach rbg wire to make them work
thanks
thanks
4pin waterproof connectors— WetSounds sells them — similar products on Amazon for cheaper.. towers may need aftermarket speaker rings depending on which ones you have.
I have a 2024 222X and want the led’s around the speakers. Can someone elaborate on the best way to do this?
Thanks!
Thanks!
Add an RGB controller and the light ring kits
