Fortress FX7 will hold your boat It holds my 21 in strong currents in sand and muck. I got 6’ of stainless chain and 2 stainless Clevises I did put little zip ties through the Clevis to make sure they did not come undone. This rope is a little more but has the stainless eye so it should not rust and stain your boat. Remember 200’ of rope this is only good to anchor in 30’ of water.
most people never put out enough rope, and most times you do not have to. I get the anchor out and the chain laying on the bottom, then I tug it a few times to get the points to start to dig in, then about 4 to one and tie it to the eye on the bow to keep it low to the water so I’m not lifting on the anchor. Put the boat in reverse and set it with a good pull. If it is windy I let out more rope first.
They all fold nice and flat, take minimal room, and come with a handy vinyl bag.Thanks for the info everyone. I’ve never used a box anchor, but will look in to them. Is there one that folds and fits in the anchor compartment on a 195?
Safety tip though, I shackle close to the flukes and zip tie at the top of the stem, that way I can break the tie and “back” the anchor out if I need to.
Is this anchor still working for you? We mainly anchor in sandy/rocky sandbars with medium current. What is the model and where did you purchase? Appreciate any help you can provide.How did it work for you?
I had the same issues with the default danforth anchor. Couldn’t get it to hold no matter what I did. Even adding chain. Tried using 6-7x depth to lead as they recommended. Backing up to get it to catch.
This year I picked up a Chene and it’s like night day. It digs right in, doesn’t need a chain and only requires 2:1 lead. Also I can squeeze it into my anchor locker (also AR195).
