What did you do to your boat today?
Is this the Yamaha 19/21FT FSH T-Top Storage bag? I'm ready to pull the trigger on one just wanted to see how you liked it or if anyone else has any input. If anyone has any other pictures or suggestions that would be great... I really like the quick access on the Yamaha one and the storage features on the inside just haven't seen one in person and can't find much on the internet about it.
Very nice! What did you plug that into to get the gauges to work? Or is it working off it’s own GPS? What’s the model number of your Garmin Plotter?
Sorry did not see this until now!
It is a Garmin Echomap UHD 93SV. It is not connected to the Yamaha system, just running its own GPS.
Not exactly the boat, but I cleaned the inside of the the boat cover today. There was some mildew spots and stains from pooling hurricane water. They cleaned up nicely. I previously cleaned the outside and used 303 Fabric Guard to refresh the material. The factory cover is really high quality. I just wish it was easier to install. I think a two-piece design with velcro would be much easier to handle.
Any tips on installing are welcome.
No pics but I also replaced the trolling motor quick disconnect receptacle. Seems the “spring” device inside the receptacle broke and the plug wouldn’t lock in and make a good connection. Easy peasy job. $25 instead of $150 to upgrade to the Minn-Kota version. We will see how long this one lasts.
Ok but why does your tire look like it is falling off the car??? First thing I saw was the wheel looks like it is loose. Any one else see that?
Regarding the tire, I see what you mean. Looks like lens distortion.
It does look funny, but it’s fine. My guess is the website photo rendering process distorted the edges.
I had one on a trailer that looked that way and when I pulled over to inspect it I realized someone was watching out for me as I was on the interstate when I noticed some odd vibration , it actually stayed on the hub I even pulled down a steep ramp and then pulled over to see what was wrong 1680028129704.jpeg
Why do you call it an AR?
Had these done last August.
My original black colored reverse buckets are starting to fade, so it's time to get creative. Just received these powder coat color samples. I guess one can figure out what I'm up to. Clearly I'm going with something Blue...!!!
AR stand for Aerial which is the tower, yamaha decided to ditch it with the new model but having an 07 and a 2019 before, I new what it AR stands for so AR252Se it is, those who know knows
wOULD Totally do it, looks badass, but it wouldnt fit in the stock location for the 252, mine is a tight fit already.
That should fit on a 252 - the Yeti45 has enough clearance for some Seadek on top.
Sorry man, I just saw this post of yours… I’ve had a T bag on my boat for a couple of years now and I really like it, I have the smaller one. It does take some fiddling with the straps to get it to hang as well as you can get it. It can sag a bit so you just have to be creative in how you run the straps to keep it from sagging too much-easey peasey.
Mine is mainly for storing the traditional PFD’s, I have it set up so access is from the the front of the CC so that access is easy and roomy. I use the two small zippered pockets to store my sun screen / bug repellent and my 12V charger adapter and cords for the iPad and I Pilot hand held remote, and my sunglasses with magnifiers in the bottom for when I have to rig tackle (or untangle a cluster) and it’s bright out. You could use it to store just about anything.
I highly recommend one.
