FSH 210 Sport
- Tranquility Base
- FSH Sport
Consider doing what I did and running a separate 12v fuse box off the house battery. That way you can tie additional accessories in later from one central, fused, location without having to worry about running or tapping off the boat's OEM current (and sensitive) 12v system.
The only thing I did not do, which I'm going to add, is a switch between the fuse box and battery to cut all power if the boat is unable to be stored on a charging system (however normally always is).
Mine looked like this:
Thanks for the super informative replies ! Especially the part about compatibility with apple products as I have them.
I ran a #10 gauge pair of wires off a 30A breaker that is fed from the switched side of the house battery switch to feed a buss bar under the helm, which in turn feeds several circuit breaker protected rocker switches, a totally separate 12V accessory supply system to keep those accessories out of the oem system, so I’ll be able to tap off of that buss bar to feed ckt breakers to the various 12V sockets and USB chargers.
