What grease/oil to use in/on the pump?
Ronnie
SF Bay Area
I'm replacing my impellers and plan to replace the grease in the pumps (in the cones at the end of the assembly) but am not sure which of the two products I bought. Here are pics of them what do you all think?
I ordered and used the Yamaha specific grease under the cone, you can use compressed air and blow out old grease from bearings into a plastic bag. When you reassemble also put grease on the splines. Also when you do the impellers put neverseize on the threads.
