What size hose goes to the cooling Pee stream fittings? 10 242 L/S
zelone
Jetboaters Commander
Croydon, PA
I remember reading here that someone replaced the plastic fittings with some billet aluminum fittings. I found a bunch of different ones online, but I don't know what size I need. If anyone has replaced them, and has a pic handy, please post is. Thanks!
Watching because I thought about doing the same thing especially when/if I install another bilge.
If anyone comes to this looking for the size to order to replace the fitting for the coolant lines, I just did my yesterday and the 1/2 fitting (45 deg.) from ADA racing fits the coolant line ones.
https://adaracing.com/personal-wate...-ski-sea-doo-4-stroke-water-bypass-45-degree/
I did have to Dremel the holes in the hull a tiny bit for the threads to fit, so just a heads up to anyone else swapping them out. It is also much easier as a 2 person job, hard to align the fittings on the outside while tightening them from the inside.
