OCMD
- Ocean City MD
- SX
Non-eth. Always. Although on my LS I ran whatver was the lowest price, and never had an issue.
Huh! That's a good reminder/refresher about the wonders of high altitude boating!Never take your boat from low altitude and fuel up with ethanol and transport the boat to high altitude. That will be one of the most frustrating experiences you can ever have. I fueled up in Page AZ, ran the boat around at lake powell but didn't go too far up lake. Then went from the 3500' altitude with a partially (3/4 tank) full tank of 87 octane 10% Ethanol gas to 6600' altitude and ended up having to filter out 3+ gallons of water from my 40 gallons of fuel.
Also, I totally loved being that guy at the ramp a month later (clean drain dry requirements for quagga) at the local lake trying to start my boat. I hate hate hate Ethanol fuel.
Normally, ethanol is added, in part, to boost octane numbers in fuel. However, at high altitude low octane fuel is fine because even though the static compression ratio of a given engine remains the same, the pressure developed during compression is lower at higher altitude. This is simply due to the lower initial pressure of the atmosphere (lower compression pressure means lower octane requirement). So - there is hardly a positive for ethanol at high altitude.
But - to make it worse - in the presence of water ethanol acts like a detergent: water molecules get surrounded by the polar heads of the ethanol at the same time pointing the aliphatic tails towards the gasoline environment. So - gasoline with ethanol can absorb a lot of water - for example from humid air, in addition to normal condensation cycles - worse in partially filled tank. And when the temperature drops... that water can subsequently separate... Ouch!
Cool idea with the adaptor! But all the new Yammies have the fuel vent in front of the gas cap and they already have fuel vapor traps built-in the vent line (presumably filled with activated carbon) - big and ugly and located by the batteries - which I guess could be drain-able. I had to move mine to free up some space for ballast bags so I had a really good look at it.A self draining adaptor is just a chamber where the fitting exiting the hull attaches below it and the hose to the tank attaches on top of it so any water would just drain back out the vent fitting. I made these about 35 years ago when people kept having issues with boats getting water in the fuel, one look at the location of the vents on some boats and the routing of the vent hoses showed the problem even with a loop in the hose that was commonly used will not always work if you are running a lot of fuel at speed and creating a vacuum in the fuel tank as it can suck in the water collecting in the loop. So having a larger void where the water stays on the bottom draining back out and air exits the top going to the fuel tank worked nicely.
I do not believe you will actually need it, your problem arose from a change from using regular fuel to ethanol fuel the system had items that were left behind from the old type fuel and additives in that fuel, if you are running only the ethanol fuel I do not believe you will have those issues. Also you said the name SEA DOO they had the worst reputation for fuel lines gumming up the fuel systems I always removed the original fuel lines when I owned those.
