Which Cover for Long Distance Travel
Mooring cover as it's made for trailering with the tower up. The shipping cover requires you to drop your tower which is fine for storage. If you're towing the boat, you must keep the tower in the upright position or use the factory shipping brackets to prevent damage - the tower bouncing over bumps will rip out the cables.
maybe some of the shipping covers are different for the 242 it fits perfect with the tower up . I have done at least 20 seasonal trips from Long Island to Vermont and upstate NY 6 hours each way. Attempted all different ways no cover, boat was filthy will never do that again and if it rained it would really be trashed with the grey cover it would rip from the wind pressure. The Weather has an impact I will change my travel dates depending on rain. Getting stuck in pouring rain having to push a 20 to 30 gallon pool of water that must have weighed 140 to 240 lbs sucked and the stress of knowing it’s pooling up.
I used my shipping cover on a 10 hour trip. It started to give up the ghost on the return trip, so I got about 16 hours out of it.
Im not sure why you only had 16 hours before it ripped again maybe different quality or did you use it for winter storage and could have UV damage. Im on 36 hrs and it’s not showing any signs of wear its only used for shipping with no poles. They also pop up for sale at a fraction of the price for what the mooring cover would cost.
I use the mooring cover without any issues. I tow without the tent poles. If I’m going to go longer distances than just to the lake, I have a giant beach ball that I inflate and put in the bow under the cover. This keeps water from pooling up if it rains. Supposedly the tent poles can rip through the cover when towing. I also bought 2 fat floaty noodles, and cut them down the middle. I put them over the top edge of the windshield frame and the little windshield bummer stop, so the cover doesn’t rub on it.
I use it for winter storage but inside my garage, so no UV damage. The outside plastic started to delaminate from the soft fleece-like material in a few spots. It made it home, but I had to tape it up. I still use it as a cover in the winter in my garage to keep dust out of the boat and it should last 20 years like that, just no more towing with it.
I removed the upper rubber bumper from my window so it doesn't rub on the cover. The window is always closed when moving so no issue with the missing bumper and it looks cleaner without it.
How do you handle it or cushion it when it is open in a chop? I don't like the bumper much either, but when we are in water that gets choppy and we are getting bounced around while fishing or go super slow, the window at times can slap a little even when snapped down.
We don't...it's closed all the time except when docked or anchored. Basically if the engines are running, it's closed.
Fair enough. I was hoping you may of come up with some cool mod. I wanted to remove the bumper for a while, since it also hangs the mooring cover when I am taking it off on the trailer getting the boat ready. The way we use the boat keeping the glass closed most of the time doesn't work out.
Sorry, not the highest quality picture, this was one my dealer sent me, but you can see the brackets bolted to the bottom of the support and the tower. I was surprised that they looked so much taller and different than what HangOutdoors had posted when I first saw this.
Thank You. Trying to figure how the Allen bolt on top of the bracket secured the tower.
If you look at my tower hinge vs. yours and the base, it makes a lot of sense why yours are longer, yours hinges higher up. Plus your tower is different. Big difference between the base model and your model :)
I used my shipping cover on a 10 hour trip. It started to give up the ghost on the return trip, so I got about 16 hours out of it. The mooring cover will create abrasions either to the window frame, unless you add cut pool noodles, and I've had those fall off, or around the edge where you tighten it.
Now I just tow it uncovered. I just leave the drain plugs out in case it rains and if I have to stop for the night at a hotel, I throw the mooring cover on it. The only thing you have to do is make sure none of your cushions will fly out. I find this much easier than covering the boat, worring if the cover will puddle with water or rub. They are meant to get wet, just me 2 cents.
Did you reinforce the unsecured cushions with velcro or do you just store them while driving?
I just store them while driving.
So you store all 3: the anchor cushion, starboard aft cushion, and engine hatch cushion? Do any of the hinged cushions blow open during highway speed travel?
Guys who are using a giant beach ball... How giant are we talking? 48"? 60"? 6 foot? The 6 footer on Amazon is mighty enticing but like 60 bucks... And maybe too big?
I store all 3. Honestly, the engine hatch one rarely get's installed since i don't like stepping on it! I've never had any of the hinged seats open on me. I also cram the mooring cover in the open seat behind the drivers seat and have never had that fly out as well. I also do a minimum of 75 MPH!
Trust me, I'm the last guy that wants to get water in my boat but they are made to get wet and a little rain ain't going to hurt. The way these are built with the self draining deck it should be no problem. Honestly, the sun will hurt it more than the rain! That said, I'd never store it sitting on shore or in the water without the cover. Keeps the bugs out!
