haknslash
- Lake Martin, AL
- Moomba
- Other
So I did my boat today in blue LED and decided to take some pics and make some edited images to help others should they do this lighting mod. If it weren't for the heat today I would have worn long sleeves because I got some nice fiberglass rash now
Here is the wiring diagram of how I wired up my 192...
I used the courtesy rocker switch at the helm to feed power and ground to the LED's...
I made little "pig tails" for my power and ground wires. There will basically be one strand of power/ground ran to the bow area of the boat and one strand of power/ground ran to the stern and around to the port side as the diagram above showed...
I used an old trick from my car stereo installer days to braid/twist 18 GA. red and black wire. Braiding the wires makes running them much easier and cleaner....
I then began running the braided wires to the starboard bow from the helm cutout. I used my sectional fiberglass rods to make this easy. I'm too big of a guy to get inside these compartments so using the rods are a life saver for most of the runs...
I put down painters tape and drilled small holes under where I wanted to hide the cockpit LED's....
Clean the surface where you want to stick your LED's with rubbing alcohol. Here you can see I tucked a good bit of the LED's up under the cushion. I didn't want to tuck all of it up in there because I wanted some of the light to flood the surrounding areas. Since the cockpit is white it will light up easily. You can go for a different more low key look but this is what I was looking for after playing around test fitting and lighting up the LED's. If you're sitting in the seat you can't even see the LED's as I wanted a hidden look. It's only unless you look underneath will you see the strips...
Then begin to wire things up...
Pics of installed LED strips...
When it came time to do the swim deck the only side that was a pain in the ass was the side with the blower. Careful of the freakin screws in there because I about ripped my fingernail off when I felt under the swim deck back cushion!! after determining where it was safe to drill on the engine compartment firewall/swim deck wall I then drilled a hole just to the low right corner of the blower next to one of the sharp ass screws...
Ok so that is my write-up on the LED install and I hope it helps someone in the future. Here's how mine turned out...
