Stacey in SC
- Charleston, SC
- Limited
Well hell! Never mind!! I guess instead of Good Luck, its CONGRATS!! And I'm jealous!
Mel, can you tell me which size roller you went with. Or the model #, thanks. Found scuff marks on our bow this spring while waxing and was a little aggravated for a boat that has very few hours on it.Maybe I need to add some of the stuff I am doing then, instead of starting new threads on them. I have a thread started on the stereo upgrade...that I didn't intend to do right now! IT IS ALL YA'LLS FAULT! LOL. I am doing the upgrade. And...get this! I never did modify my bow roller on my 230, because it never, not even once, marked up my hull. Now I have this new Shorelander, which I think is a fabulous trailer, but the "poly bow roller" is flat out leaving poly all over the bow hull! So I immediately bought a new Stoltz Bow Roller and changed it. Check this out!
That's great Mel......You put a lot of time in to those trailer guides and they look great.I finished the LED guide post lights. I painted the square tubing support to match the trailer, as well as the bottom channel support. I drilled the square tubing inside the frame rail, and installed the light cable internally this time. I have to say pulling a cable through that bend is tough, but I got er done. I then spliced, soldered, and waterproofed the connection in the trailer end frame. I cut the LED stock cable 12" below the LED and put in posi-lock connectors, so that I can remove them easy this time if I need to straighten the square tubing. This mod ended up taking MUCH longer than I expected. I can't tell you how hard it was to fish that wire through that square tubing and PVC upright. I broke the tape holding the wire to the fish tape twice, got the wire stuck once and didn't want to break it. So I finally pushed the fish tape through from the top and dislodged it and pulled it back out the bottom. Then I used a vacuum to suck a string up and out to pull the wire through...and broke that 3 times. Finally, after keeping after it, I got the second one. Not feeling 100% today, so had to take a few breaks and move slow.
I also installed the Cobra EZ Locks on my clean out plugs!
@DawgDaze , I found another hitch pin lock that works and I like better. It is like the one you have, but a wider opening to accommodate the new style hitch.
