swatski
Jetboaters Fleet Admiral 1*
- North Caldwell, NJ
What are you rpm at WOT?Out of the hole it's perfectly fine, just can't get above 15 mph
I'm going to double check the caulk,,,, which is the best I should be using? Should I remove it completely and then re-caulk or just patch?
You may have this covered in the link you sent me but again I'm still at work and cannot do that until tonight
(Max rpm)
You should be over 7,000 rpm, ideally close to 7,700-7,800 with little or no cavitation on the hole shot (which you appear to have).
