FSH 210 Sport
- Tranquility Base
- FSH Sport
I have the Dakota 36v 63AH single battery and just got to use it last weekend. I spot locked for about 4 hours and trolled for 1 hour and the ipilot link controller was showing full battery for the Dakota. Not sure if it was accurate or not, but when I got home, it only took 45 mins to fully charge with the included 8ah charger from Dakota.
Great results!
Be careful with the ipilot link controller battery monitor… it is set up for lead acid batteries. LiFePO batteries hold their voltage till the very end then the voltage drops off sharply, at roughly 90% discharge the voltage is still 12.6V, so your ipilot link monitor will still show full. I don’t know which troller you have, if you have a manual deploy type then it isn’t that big of a worry. But if you have the self deploying model you could have issues. One time with my lead acid batteries the motor just stopped providing thrust, it was still on but wouldn’t spin the prop. I checked the battery indicator on the remote and it had the slimmest of red lines in the battery indicator, I was able to stow the motor for the rest of the day. Others with the Lithium batteries have had the motor just shut off completely and they had to remove it from the mount.
I highly recommend a Victron energy smart shunt to monitor your trolling motor battery.. they are not that much money, maybe $125, and are super easy to set up. It will show state of charge, Ah used, KWh used and voltage.
