Cambo
- Long Island
- 242X E-Series
The Kit is a complete plug and play solution that allows you to control the ballast pumps from a series of switches to fill and empty the ballast bags without using the Yamaha System. The Yamaha system is not very comprehensive and is plagued with timer issues, making it very difficult to get to the proper fill and empty capacities. This is the next generation from the pump jumper cable that was very successful https://jetboaters.net/threads/ballast-pump-jumper-cable.19754/
Cost is $260.00 + $25.00 shipping to the lower 48 PM me for payment options
The kit consists of:
Other Benefits include the ability to expand on the existing system with some simple piping and fittings to run the pumps to fill other bags, like a transom bag, eliminating the need for a separate $170.00 tsunami pump. Or, with the addition of fittings and hoses, add additional ballast bags using the existing pumps. Have your spotter adjust the pumps as necessary to clean up the wake for wake boarding, so your passengers don't have to move around to balance the boat.
The boat motors do not have to be on to run the pumps this will allow trouble shooting and the ability to drain water from the center ballast bag that partially fills by itself from a siphoning effect. It can also be used for winterizing of the ballast system.
Eliminate the need for an over the side pump you can easily run two hoses and fill the transom bag from two stock pumps with the quick flip of the ball valves to redirect the water .
Buy these fittings, hoses, and hose clamps separately to expand the ballast system using the stock pumps.
- 3 pre-wired switches with cables that pug directly into the factory pump connectors
- Separate on off switch to eliminate any accidental engagement of the switch
- A piezo beeper to let you know if the pumps are activated
- 30 amp fused Power connection wire with ring terminals
- General directions
