ScottS
- Salt Lake City, Utah
- AR195
Definitely cavitation burns on the face of your impeller. How is the gap between the leading edge of your impeller and the wear ring/side of the tunnel? Is it consistent? I think it should be something like .023” to .03” (Anyone feel free to correct me) which should be tight and consistent all the way around. If it looks like there is spalling on the leading edges, an inconsistent gap between the impeller and the side, and/or damage to the wear ring/sidewall, these will all affect your performance.
Confirm that you installed the correct spark plugs as well - NGK LFR6A (SX195 uses NGK LFR7A) at a gap of 0.8-0.9 mm or 0.031-0.035 in
