2023 255xd Maptuner X tunes
The RIVA kits are such a rip off for sure. I have modded 26 SVHO waverunners in total since 2015. 8 of which were mine and the rest friends. I’ve never spent an anything near $3,000, and all of them have done 82-86mph on GPS.
I buy the parts through GreenHulk or Dean’s Team as package deals without paying the markup of the riva “stage” kits. All of them are a little more involved than a stage 1+, but less than a stage 2, all for less $ than a stage 1.
The last one I did was a 2022 FX back in 2023. It cost $2100 in parts including the $500 license. That was after the fizzle intercooler was bumped up to $1000.
We are looking to spend about $4,100 in total on this boat.
$1000 each for the intercoolers.
$500 each license.
$250 each Impellers.
$200 each air intakes.
$100 each in cooling parts
Going to set limiter to 8800 RPM. Dean’s team 93 octane tunes.
I’ll try to remember to update here with top speed improvements. Hoping to see some acceleration gains too!
How did this work out?
If it was amazing results i am sure we would have heard
Reply from Jesus @ Riva
Right now we are starting a program to develop specific packages , same way we do for PWCs.
For now, we do have the tunes and the upgrade for the filter, replace the OEM screen for a bigger one to get more air flow.
I would do that, then depending on the results (RPM wise) and your target, send the impeller to IMPROS to be modified…
And
There
It
Is.
Ok, So I did it. but the heat and humidity robbed it all back.
As I stated before my boat has always been on the slow side. 54mph best stock.
But while running the twin stacked impellers 51mph was best
On July 12th started testing tune
stage 1 8300rpm. 12/20 twins 54mph @ 7600. stock cones (no L13)
on July 13th
stage 1 8300rpm 12/18 twins stock cones (no L13). 56mph @ 8000 port / 7700 starboard..
that is with full fuel, 4 people, 4 200ah 6v batteries, 4 12" subs and other gear.
The last two weekends 7/19 & 7/26 has been with the 12/18 twins but with heat 95+. humidity 80% and 88-90 water temp. I was only seeing 52mph 7500-7700rpm. it felt like i was hitting a wall at the top end.
But with the early July12/13 testing I picked up 4-5 mph while using the twin stacked impellers.
This weekend I will put the stock impellers back on and test. But we are set to have lower temps so that does not help testing.
editing: I only run 91 octane . 93 is a pain to find
This subject has been brought up time an again. So far the results from any mods and tunes have been minimal. The 255 boats with the svhos might get more out of tunes and mods but from what i have seen it wont be worth the money spent
If you are worried about money and into this style of jetboat you're in the wrong hobby. A 255xd drinks gas like no other at full throttle. But if you shop smart and find deals it helps I bought the MapX tunner last year new for half price from a former member.
I got 10% or so off the tunning from PWC Performance Parts.
The Twin stack impellers I bought off the the shelf and have the same results as others have seen with the ones that were tuned at almost 2 times the price.
I like the chase I wish it was a bit easer but....
This is an option but I have no first had knowledge with them Jetboat ECU Tuning (Number of Engines: Dual)
Money is not the problem, i will spend money on just about anything that gives me clear results that warrant the cost.
I have plenty of toys that are far from stock and i spent plenty on them to make them great machines.
Tunes and mods on these boats dont translate to big improvements like a 700lb ski does.
I’m with @jacoviii on this I think. I enjoy making improvements even though I know they’ll be small. I’d like to get my big ass, heavy 255XD over 60mph. I don’t mind spending the money if I’m having fun.
on July 13th
Why not leave the same impellers in and test in cool conditions?
Also I’d suggest figuring out the density and recording that with your test results.
How was the hole shot and was there any cavitation?
Your twin screws are off the shelf correct? You could probably have those feathered in for the best compromise as well.
So on 7/19 running the 12/18 only hitting 51-52 we were at LOZ lake elevation 659ft but this was the weather
  • Jul 19 2:00 pm
  • 92 deg F
  • 59%
  • 29.23 Hg
  • 76 deg F
  • 137.3
  • 12 mph
  • SW (233)
  • 89.213 % AD
  • 3856 ft. DA
back home at Smithville lake 864ft the 2 examples are from the 2 closes race ways to the lake
  • elev. 759ft
  • Jul 26 2:00 pm
  • 89 deg F
  • 67%
  • 29.12 Hg
  • 77 deg F
  • 142.6
  • 7 mph
  • SW (217)
  • 89.256 %
  • 3840 ft.
  • elev. 1013ft
  • Jul 26 2:00 pm
  • 86 deg F
  • 77%
  • 28.82 Hg
  • 78 deg F
  • 150.9
  • 7 mph
  • SW (199)
  • 88.646 %
  • 4068 ft.
FSH thank you I have been going about this with a few assumptions. Like I know that I boat between 600' and 800' mostly. So not a huge of a difference from "sea level". But now looking at he numbers I'm in the mountains. LOL. After this coming weekends findings I will get ahold of Riva for a custom tune for this Zone.
hole shot was good but "water temp" does loosen it up a bit.
Yes they are straight as solas makes them. I will work on custom pitches as time comes.
with the large swing in temp and humidity. I foresee a spring / fall impeller set and a peak summer set. but only testing will tell.
I can change them out in about 35 min now but would rather not have too.
Right on …
I looked up the batteries you have, I’m assuming Duracell 6V 200Ah weigh 64# each, so that’s 256# of batteries = significant. You could drop 224# (equivalent to a big dude) of that weight and have more capacity if you were to go with two 100Ah LFP batteries. That in and of itself would have to be worth a few mph.
I thought that the wake series of boats also ran their pumps slightly toed in to enhance the wake. I wonder what effect it would have if you were to point the jets straight back?
Just be careful to make one change at a time under as close to the same atmospheric conditions to eliminate any unwanted variables that will not only confuse results but make those results unrepeatable. This kind of stuff takes a lot of time and patience….
I did A LOT of testing learning how to jet a FCR carb on my 550 Husaberg. I got it to where all I had to do was change needles when I went from 3000’ to 9000’. I’ve also done a lot of suspension testing. All of that took a lot of time and patience but in the end it was totally worth it worth it.
I still think the twin screw or inducer style of impeller is the key to the best all around performance with little to no cavitation. You’ll just have to decide the best compromise pitch, obviously if get optimum rpm at higher DA, you’ll be under propped at low DA.. I’m speaking for myself of course as I wouldn’t want to be swapping impellers for a DA difference of a couple thousand feet. I do change mine when I go from 5000’ above msl and possible DA of 10,600’ to 500’ above msl and DA of 1200’.
So you’re running your DA numbers based on outside air temp. If you hang a thermometer in the engine bay you’ll be amazed at how hot the intake air is. I checked mine recently on a 92° after cruising around at best cruise and it was 135° on the fire wall about 4” from the intake. When you use that temp your DA skyrockets.
The plan for next year is to be running lithium/lipo.
The nozzles are already aligned straight. (I actually made to small brackets so I can adjust nozzle angles from inside the boat in less than 2 minutes. I can go from surf to cruising just like that.)
I will monitor the engine bay temperature next outing.
I would really like to see and know more about these brackets.
I looked at your other thread and then read this one. I’m no good at spread sheets otherwise I’d offer to help you make one but a spread sheet would be helpful with this testing to help keep things organized.
It seems like there are quite a few variables that could be affecting your results, density altitude, wind, fuel load, people load, cargo load, lucky 13 cones & shim stack, stock tune, riva tune, and riva air filters? Then there’s the whole kinesthetic aspect to think about.
When you did your testing last year, did you have the 6 200Ah batteries, 4 12” subs, and the other gear in the boat? What was the total weight then? I don’t remember seeing it. I mentioned that above and you responded but I think keeping track of the fuel load and total added weight to the boat along with the DA would provide a clearer picture of this whole process. You’ve already got a lot of data points just having them illustrated in a way that makes them easy to see might be helpful.
The good news is that see is that there doesn’t seem to be any cavitation in your testing thus far which is great.
I know I already said it, but I’d stick with the last set of impellers you were using in the forecasted cooler conditions / lower DA.
Maybe a newb question but it seems Jesus was saying to do the tune/ upgrades and then see where RPM ends up before choosing impeller pitch?
Yes boat load out was the same
Yes. Because a tune is easier "physically". He knows what the tune should do for/to the motors and in theory after a tune if the you can say "O my top end RPMs are low/high do this to the impellers. But I did buy impellers first. Due to cost and if I didn't lose any/or much top speed and fixed the low speed while surfing cavitation. A tune would not be need. I did achieve no cavitation with the use of twin stacked impellers and was on a good weather day within an acceptable top speed. But the MOD bug bit and now I'm exploring tunes.
